Saltar al contenido principal
Samsung SGH-A237 Keypad Replacement
Qué necesitas
  1. Samsung SGH-A237 Keypad Replacement, Keypad: paso 1, imagen 1 de 2 Samsung SGH-A237 Keypad Replacement, Keypad: paso 1, imagen 2 de 2
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: paso 2, imagen 1 de 2 Samsung SGH-A237 Keypad Replacement: paso 2, imagen 2 de 2
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: paso 3, imagen 1 de 2 Samsung SGH-A237 Keypad Replacement: paso 3, imagen 2 de 2
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: paso 4, imagen 1 de 3 Samsung SGH-A237 Keypad Replacement: paso 4, imagen 2 de 3 Samsung SGH-A237 Keypad Replacement: paso 4, imagen 3 de 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: paso 5, imagen 1 de 1
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: paso 6, imagen 1 de 2 Samsung SGH-A237 Keypad Replacement: paso 6, imagen 2 de 2
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: paso 7, imagen 1 de 1
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Conclusión
Shawn
Miembro Desde 04/14/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 29-81, Johann Spring 2010 Miembro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Miembros
8 Guías creadas
Un comentario
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 2,315
