Saltar al contenido principal
Samsung SGH A707 Front Pane Replacement
Qué necesitas
  1. Samsung SGH A707 Front Pane Replacement, Battery: paso 1, imagen 1 de 1
    • Press on the markings on the cover and pull it down to reveal the battery.
  2. Samsung SGH A707 Front Pane Replacement: paso 2, imagen 1 de 1
    • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
  3. Samsung SGH A707 Front Pane Replacement: paso 3, imagen 1 de 1
    • Here is the phone without the battery.
  4. Samsung SGH A707 Front Pane Replacement, Motherboard: paso 4, imagen 1 de 2 Samsung SGH A707 Front Pane Replacement, Motherboard: paso 4, imagen 2 de 2
    • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
  5. Samsung SGH A707 Front Pane Replacement: paso 5, imagen 1 de 1
    • Use the prying tool the pry off the phone's plastic frame.
  6. Samsung SGH A707 Front Pane Replacement: paso 6, imagen 1 de 3 Samsung SGH A707 Front Pane Replacement: paso 6, imagen 2 de 3 Samsung SGH A707 Front Pane Replacement: paso 6, imagen 3 de 3
    • Use the prying tool to disconnect the rectangular connector.
  7. Samsung SGH A707 Front Pane Replacement: paso 7, imagen 1 de 1
    • Use the prying tool to disconnect the small connector.
  8. Samsung SGH A707 Front Pane Replacement: paso 8, imagen 1 de 1
    • Gently pull off the circuit board.
  9. Samsung SGH A707 Front Pane Replacement: paso 9, imagen 1 de 1
    • Here is the phone without the logic board.
  10. Samsung SGH A707 Front Pane Replacement, Keypad: paso 10, imagen 1 de 1
    • Hold the phone and gently separate the circuit board that holds the dome switches and the front face of the phone, revealing the rubber keyboard.
  11. Samsung SGH A707 Front Pane Replacement: paso 11, imagen 1 de 1
    • Here is the phone without the dome switch circuit board.
  12. Samsung SGH A707 Front Pane Replacement: paso 12, imagen 1 de 2 Samsung SGH A707 Front Pane Replacement: paso 12, imagen 2 de 2
    • Here is the phone and the rubber keyboard.
  13. Samsung SGH A707 Front Pane Replacement: paso 13, imagen 1 de 1
    • Here is the rubber keyboard and the dome switch circuit board. A quick inspection of these elements can reveal keypad malfunctions. Look for dirt or debris that do not belong there.
  14. Samsung SGH A707 Front Pane Replacement, Front Pane: paso 14, imagen 1 de 2 Samsung SGH A707 Front Pane Replacement, Front Pane: paso 14, imagen 2 de 2
    • Use the Phillips #0 screw driver to remove the two screws.
    • Place the screws in a safe place.
    • Use the prying tool to gently pry the screen off, by slowly moving the prying tool around the entire edge of the screen (roughly highlighted with a red rectangle). You must be very gentle, otherwise the screen will crack.
  15. Samsung SGH A707 Front Pane Replacement: paso 15, imagen 1 de 1
    • Now we have access to the camera.
    • We also have access to the speakers.
    • Disconnect the flat cable to separate the two pieces.
  16. Samsung SGH A707 Front Pane Replacement: paso 16, imagen 1 de 1
    • Samsung SGH A707
Conclusión
yfm
Miembro Desde 11/06/12
25 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 691
