Saltar al contenido principal
Samsung SCH-A950 Volume and Camera Buttons Replacement
Qué necesitas
  1. Samsung SCH-A950 Volume and Camera Buttons Replacement, Battery: paso 1, imagen 1 de 2 Samsung SCH-A950 Volume and Camera Buttons Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Volume and Camera Buttons Replacement, Volume and Camera Buttons: paso 2, imagen 1 de 1
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Volume and Camera Buttons Replacement: paso 3, imagen 1 de 2 Samsung SCH-A950 Volume and Camera Buttons Replacement: paso 3, imagen 2 de 2
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Volume and Camera Buttons Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Volume and Camera Buttons Replacement: paso 5, imagen 1 de 3 Samsung SCH-A950 Volume and Camera Buttons Replacement: paso 5, imagen 2 de 3 Samsung SCH-A950 Volume and Camera Buttons Replacement: paso 5, imagen 3 de 3
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
Conclusión
Una persona más ha completado esta guía.
Sean Kennedy
Miembro Desde 01/13/10
49 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-5, Forte Winter 2010 Miembro de Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,865
