Saltar al contenido principal
Samsung SCH-A950 Logic Board Replacement
Qué necesitas
  1. Samsung SCH-A950 Logic Board Replacement, Battery: paso 1, imagen 1 de 2 Samsung SCH-A950 Logic Board Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Logic Board Replacement, Volume and Camera Buttons: paso 2, imagen 1 de 1
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Logic Board Replacement: paso 3, imagen 1 de 2 Samsung SCH-A950 Logic Board Replacement: paso 3, imagen 2 de 2
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Logic Board Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Logic Board Replacement: paso 5, imagen 1 de 3 Samsung SCH-A950 Logic Board Replacement: paso 5, imagen 2 de 3 Samsung SCH-A950 Logic Board Replacement: paso 5, imagen 3 de 3
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
  6. Samsung SCH-A950 Logic Board Replacement, Speakers: paso 6, imagen 1 de 2 Samsung SCH-A950 Logic Board Replacement, Speakers: paso 6, imagen 2 de 2
    • Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
    • Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
  7. Samsung SCH-A950 Logic Board Replacement: paso 7, imagen 1 de 1
    • Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
  8. Samsung SCH-A950 Logic Board Replacement: paso 8, imagen 1 de 1
    • Push the speaker out of the phone using the spudger.
  9. Samsung SCH-A950 Logic Board Replacement: paso 9, imagen 1 de 1
    • Remove the speaker from the decorative housing by pulling on the wires.
    • The speaker can be replaced if needed.
  10. Samsung SCH-A950 Logic Board Replacement, Logic Board: paso 10, imagen 1 de 1
    • Using a plastic opening tool, disconnect the display cable from the motherboard.
  11. Samsung SCH-A950 Logic Board Replacement: paso 11, imagen 1 de 1
    • Use a plastic opening tool to pry the motherboard away from the phone housing at the tabs on both sides of the phone at the pictured location. Some force may be required.
  12. Samsung SCH-A950 Logic Board Replacement: paso 12, imagen 1 de 1
    • The logic board will pop out.
    • The logic board can be replaced if needed.
Conclusión
Alan Cook
Miembro Desde 01/13/10
44 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-5, Forte Winter 2010 Miembro de Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,578
