Introducción
This guide will teach you how to remove your Samsung ACH-A950's keyboard.
Qué necesitas
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Remove the four Phillips #00 screws underneath the battery.
Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
Using a plastic opening tool, disconnect the display cable from the motherboard.
Once the logic board has been removed, the keyboard is exposed and can be removed by simply lifting the keyboard out of the phone housing.
The keyboard can be replaced if needed.
