Saltar al contenido principal
Samsung SCH-A890 Front Screen Replacement
Qué necesitas
  1. Samsung SCH-A890 Front Screen Replacement, Front Screen: paso 1, imagen 1 de 2 Samsung SCH-A890 Front Screen Replacement, Front Screen: paso 1, imagen 2 de 2
    • Open the device so that the inside of the phone is facing you.
    • Remove the small, gray, circular covers on the bottom left and right corners of the inside face of the phone.
  2. Samsung SCH-A890 Front Screen Replacement: paso 2, imagen 1 de 1
    • Use the size 00 screwdriver to remove the two small screws underneath the removed covers.
    • The screws are slightly magnetic and will want to stay in place. May have to follow the next step and get the cover off, then poke the screws out.
  3. Samsung SCH-A890 Front Screen Replacement: paso 3, imagen 1 de 2 Samsung SCH-A890 Front Screen Replacement: paso 3, imagen 2 de 2
    • Insert the spudger between the top and bottom plates to pry the cover off.
    • You may need to gently slide the spudger up and down to loosen the cover without snapping it.
    • Alternate between sides to loosen the cover more safely and effectively.
  4. Samsung SCH-A890 Front Screen Replacement: paso 4, imagen 1 de 2 Samsung SCH-A890 Front Screen Replacement: paso 4, imagen 2 de 2
    • Carefully remove the cover off the device without scratching the display or harming the components.
    • Work in a dry, dust-free environment to prevent liquid or dust particles from entering the components.
Conclusión
Casey Burke
Miembro Desde 01/14/10
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-10, Forte Winter 2010 Miembro de Cal Poly, Team 5-10, Forte Winter 2010
CPSU-FORTE-W10S5G10
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,382
