Introducción
Though it would be considerably difficult to damage the keypad, stranger things have happened. Also, after long term use, the keys themselves may become dirty and start to stick when being pressed. In order to solve both of these issues, you may need to open up the phone and either replace the keypad (in the case of damage) or to simply clean it off and clean the inside of the case to prevent further sticking. This guide takes you through the process of getting to the keypad.
Qué necesitas
Using a #00 Phillips Screwdriver, remove the 4 (3mm) black screws from each corner of the back casing.
Use the wide plastic prying tool to open the back case.
To make this process easier, use the tool to push against this tab while gently pulling the back upward.
Repeat this process on the opposite side.
The volume button may fall out, but don't force it back in. Set it aside for reassembly.
When replacing the volume button, the rubber tab must be placed carefully into the space in the inner casing.
Fold the circuit board back like a book cover just as you did with the back plate.
Be careful of this connector which goes to the front of the phone.
The silver contacts on the bottom of the motherboard are what recognize key presses; if the phone isn't responding to key presses, you will need to replace the motherboard here.
