Saltar al contenido principal
Samsung SCH-8500 Volume Button Replacement
Qué necesitas
  1. Samsung SCH-8500 Volume Button Replacement, Battery: paso 1, imagen 1 de 3 Samsung SCH-8500 Volume Button Replacement, Battery: paso 1, imagen 2 de 3 Samsung SCH-8500 Volume Button Replacement, Battery: paso 1, imagen 3 de 3
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Volume Button Replacement, Back Case: paso 2, imagen 1 de 3 Samsung SCH-8500 Volume Button Replacement, Back Case: paso 2, imagen 2 de 3 Samsung SCH-8500 Volume Button Replacement, Back Case: paso 2, imagen 3 de 3
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. Samsung SCH-8500 Volume Button Replacement, Volume Button: paso 3, imagen 1 de 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: paso 3, imagen 2 de 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: paso 3, imagen 3 de 3
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
Conclusión
Will Gunter
Miembro Desde 10/23/12
1 Reputación
4 Guías creadas
Equipo
Clemson, Team 14-6, Benson Fall 2012 Miembro de Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 191
