Partes
No se requieren partes.
  1. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
    • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  2. Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Lift battery away from phone case.
    • The battery is now removed from the device. Congratulations.
    • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
    • When unscrewed, pull the antenna straight up and out.
    • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
    • The antenna and its guide tube are now removed from the phone. Congratulations.
    • Remove the four screws using a T6 Torx screwdriver.
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
    • Remove the connector for the earpiece speaker, located on the upper end of the logic board.
    • Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
    • Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered.
    • The logic board is now removed from the phone. Congratulations.
Conclusión
Equipo
Clemson, Team 2-6, Benson Spring 2012 Miembro de Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Miembros
10 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 711
