Saltar al contenido principal
Samsung SCH-3500 Antenna Replacement
  1. Samsung SCH-3500 Antenna Replacement, Battery: paso 1, imagen 1 de 2 Samsung SCH-3500 Antenna Replacement, Battery: paso 1, imagen 2 de 2
    • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
  2. Samsung SCH-3500 Antenna Replacement: paso 2, imagen 1 de 1
    • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
  3. Samsung SCH-3500 Antenna Replacement: paso 3, imagen 1 de 1
    • Lift the battery away from the phone case.
  4. Samsung SCH-3500 Antenna Replacement, Antenna: paso 4, imagen 1 de 2 Samsung SCH-3500 Antenna Replacement, Antenna: paso 4, imagen 2 de 2
    • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
  5. Samsung SCH-3500 Antenna Replacement: paso 5, imagen 1 de 1
    • When unscrewed, pull the antenna straight up and out.
  6. Samsung SCH-3500 Antenna Replacement: paso 6, imagen 1 de 2 Samsung SCH-3500 Antenna Replacement: paso 6, imagen 2 de 2
    • Pull the guide tube free from its retaining ring and slide it out the top.
Conclusión
Equipo
Clemson, Team 2-6, Benson Spring 2012 Miembro de Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 736
