Saltar al contenido principal
Samsung S860 Logic Board Replacement
Qué necesitas
  1. Samsung S860 Logic Board Replacement, Battery: paso 1, imagen 1 de 3 Samsung S860 Logic Board Replacement, Battery: paso 1, imagen 2 de 3 Samsung S860 Logic Board Replacement, Battery: paso 1, imagen 3 de 3
    • With the camera facing LCD side up, slide the battery compartment lid to the right.
    • Remove the old batteries.
  2. Samsung S860 Logic Board Replacement, LCD Screen: paso 2, imagen 1 de 2 Samsung S860 Logic Board Replacement, LCD Screen: paso 2, imagen 2 de 2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  3. Samsung S860 Logic Board Replacement: paso 3, imagen 1 de 1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  4. Samsung S860 Logic Board Replacement: paso 4, imagen 1 de 3 Samsung S860 Logic Board Replacement: paso 4, imagen 2 de 3 Samsung S860 Logic Board Replacement: paso 4, imagen 3 de 3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  5. Samsung S860 Logic Board Replacement: paso 5, imagen 1 de 2 Samsung S860 Logic Board Replacement: paso 5, imagen 2 de 2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
  6. Samsung S860 Logic Board Replacement, Logic Board: paso 6, imagen 1 de 2 Samsung S860 Logic Board Replacement, Logic Board: paso 6, imagen 2 de 2
    • Using a #00 Phillips screwdriver, remove the six 4.3 mm screws along the edges of the camera.
    • Save them for putting the camera back together.
  7. Samsung S860 Logic Board Replacement: paso 7, imagen 1 de 1
    • Turn the bottom edge of the camera towards you.
    • Slide open the battery chamber.
    • This must be done to remove the exterior covers of the camera.
  8. Samsung S860 Logic Board Replacement: paso 8, imagen 1 de 3 Samsung S860 Logic Board Replacement: paso 8, imagen 2 de 3 Samsung S860 Logic Board Replacement: paso 8, imagen 3 de 3
    • Carefully pull the back of the camera (the LCD screen side) away from the front.
    • Turn the camera to the front (the flash side) and pull the case off.
    • There are clips on both sides of the case that secure it to the camera, so you may need to use a bit of force to remove the case.
  9. Samsung S860 Logic Board Replacement: paso 9, imagen 1 de 2 Samsung S860 Logic Board Replacement: paso 9, imagen 2 de 2
    • Orient the camera so the LCD screen is facing you.
    • Remove any tape holding the screen down.
    • Lift the LCD screen from the screen plate.
    • Lift the hinged lip where the ribbon enters the connector.
    • Remove the ribbon from the logic board by gently pulling it away from the logic board.
  10. Samsung S860 Logic Board Replacement: paso 10, imagen 1 de 1
    • Using a #00 Philips screwdriver, remove the two 4.5 mm screws from the screen plate.
    • Separate the screen plate and logic board.
  11. Samsung S860 Logic Board Replacement: paso 11, imagen 1 de 1
    • Locate the ribbon attached to the upper left edge of the logic board.
    • Remove this ribbon by gently pulling in the opposite direction of the logic board. The "ears" on the cable can be used to help pull it free.
  12. Samsung S860 Logic Board Replacement: paso 12, imagen 1 de 1
    • Using a #00 Philips screwdriver, remove the three 3.32 mm screws connecting the logic board to the camera.
    • Separate the logic board and the core of the camera.
  13. Samsung S860 Logic Board Replacement: paso 13, imagen 1 de 1
    • Separate the logic board by carefully pulling the logic board away from the camera.
    • Be careful not to damage the battery compartment. The battery sensors are attached to the logic board, so be gentle.
    • The USB connector is going to want to hang up on the housing, but once you have that free, the battery leads will slide out relatively easily.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 33-72, Johann Spring 2010 Miembro de Cal Poly, Team 33-72, Johann Spring 2010
CPSU-JOHANN-S10S33G72
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 9,382
