Saltar al contenido principal
Introducción
This guide will show a user how to take off the rubber door for replacement.
Partes
No se especificaron partes.
  1. Samsung S85 Rubber Door Replacement, Rubber Door: paso 1, imagen 1 de 3 Samsung S85 Rubber Door Replacement, Rubber Door: paso 1, imagen 2 de 3 Samsung S85 Rubber Door Replacement, Rubber Door: paso 1, imagen 3 de 3
    • Remove 4 screws from bottom of camera
    • Remove 2 screws from side of camera
    • Place Screws on magnetic surface or location where they will not roll away
  2. Samsung S85 Rubber Door Replacement: paso 2, imagen 1 de 1
    • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
  3. Samsung S85 Rubber Door Replacement: paso 3, imagen 1 de 2 Samsung S85 Rubber Door Replacement: paso 3, imagen 2 de 2
    • Remove 6 screws identified by red circles
    • Remove 3 screws identified by orange circles
  4. Samsung S85 Rubber Door Replacement: paso 4, imagen 1 de 2 Samsung S85 Rubber Door Replacement: paso 4, imagen 2 de 2
    • Gently remove orange circuit ribbon identified by red square
    • Gently remove narrow orange circuit ribbon identified by blue square
  5. Samsung S85 Rubber Door Replacement: paso 5, imagen 1 de 3 Samsung S85 Rubber Door Replacement: paso 5, imagen 2 de 3 Samsung S85 Rubber Door Replacement: paso 5, imagen 3 de 3
    • Be very cautious when using a soldering iron (they are on average 300 F)
    • Using a soldering iron, remove solder from wire identified by red circle
    • Using a soldering iron, remove solder from black and red wire identified by orange circle
    • Using a soldering iron, remove solder from wire identified by yellow circle
  6. Samsung S85 Rubber Door Replacement: paso 6, imagen 1 de 3 Samsung S85 Rubber Door Replacement: paso 6, imagen 2 de 3 Samsung S85 Rubber Door Replacement: paso 6, imagen 3 de 3
    • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
    • Repeat step two to three times until board feels flexible to bend
    • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
  7. Samsung S85 Rubber Door Replacement: paso 7, imagen 1 de 1
    • Remove black rubber door located on side of camera closest to lens using tweezers.
    • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 205
