Introducción
This guide will show a user how to take off the rubber door for replacement.
  1. Remove 4 screws from bottom of camera Remove 2 screws from side of camera Remove 2 screws from side of camera
    • Remove 4 screws from bottom of camera
    • Remove 2 screws from side of camera
      • Place Screws on magnetic surface or location where they will not roll away
  2. Squeeze area noted by blue square and pull outside shell apart from remaining camera.
    • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
  3. Remove 6 screws identified by red circles Remove 3 screws identified by orange circles
    • Remove 6 screws identified by red circles
    • Remove 3 screws identified by orange circles
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  5. Gently remove orange circuit ribbon identified by red square Gently remove narrow orange circuit ribbon identified by blue square
    • Gently remove orange circuit ribbon identified by red square
    • Gently remove narrow orange circuit ribbon identified by blue square
  6. Be very cautious when using a soldering iron (they are on average 300 F) Using a soldering iron, remove solder from wire identified by red circle Using a soldering iron, remove solder from black and red wire identified by orange circle
    • Be very cautious when using a soldering iron (they are on average 300 F)
    • Using a soldering iron, remove solder from wire identified by red circle
    • Using a soldering iron, remove solder from black and red wire identified by orange circle
    • Using a soldering iron, remove solder from wire identified by yellow circle
  7. Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture Repeat step two to three times until board feels flexible to bend Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
    • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
    • Repeat step two to three times until board feels flexible to bend
    • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
  8. Remove black rubber door located on side of camera closest to lens using tweezers.
    • Remove black rubber door located on side of camera closest to lens using tweezers.
      • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
Conclusión
Una persona más ha completado esta guía.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 151
