Saltar al contenido principal
Samsung S85 Outside Casing Replacement
Qué necesitas
  1. Samsung S85 Outside Casing Replacement, Outside Casing: paso 1, imagen 1 de 3 Samsung S85 Outside Casing Replacement, Outside Casing: paso 1, imagen 2 de 3 Samsung S85 Outside Casing Replacement, Outside Casing: paso 1, imagen 3 de 3
    • Remove 4 screws from bottom of camera
    • Remove 2 screws from side of camera
    • Place Screws on magnetic surface or location where they will not roll away
  2. Samsung S85 Outside Casing Replacement: paso 2, imagen 1 de 2 Samsung S85 Outside Casing Replacement: paso 2, imagen 2 de 2
    • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 357
