Introducción
This guide will show users how to remove and replace the lens unit if the unit is malfunctioning or damaged.
Qué necesitas
Remove 8 screws securing outside shell. Screw locations can be found in pictures
After removing you see a few wires and a screen placed on top of the circuit board looking similar to the first picture. If you don't, you might have not taken apart the wrong camera, yikes!
The second picture outlines where you can locate all the surface screws. Note that these will not be the only screws needed to be taken off to remove the circuit board.
As shown in the third picture be careful when removing the screw hidden behind the circuit.
Using screwdriver, remove silver metal piece located in center of camera.
Using tweezers, gently remove orange circuit from lens. This step is tricky as the orange circuit is very securely placed in the lens.
After the removal of the silver piece and orange circuit remove black circle from center of camera. This is the lens
Gently remove top portion of lens as shown in the third picture.
To reassemble your device we have provided pictures working backwards.
Una persona más ha completado esta guía.
