Saltar al contenido principal
Samsung S630 LCD Display Replacement
Qué necesitas
  1. Samsung S630 LCD Display Replacement, LCD Display: paso 1, imagen 1 de 1
    • Here is my Samsung S630. Nice little camera with just one flaw. The LCD display was broken.
  2. Samsung S630 LCD Display Replacement: paso 2, imagen 1 de 3 Samsung S630 LCD Display Replacement: paso 2, imagen 2 de 3 Samsung S630 LCD Display Replacement: paso 2, imagen 3 de 3
    • Remove the two screws on the left side.
    • Remove the two on the right side.
    • Remove the four screws on the bottom. All eight screws are the same, so no need to ensure proper position when reassembling.
  3. Samsung S630 LCD Display Replacement: paso 3, imagen 1 de 1
    • Open the battery cover and split the housing carefully. Start at the battery compartment and work your way around it. You can use an opening tool or your fingernails. Also make sure to open the USB port cover.
  4. Samsung S630 LCD Display Replacement: paso 4, imagen 1 de 3 Samsung S630 LCD Display Replacement: paso 4, imagen 2 de 3 Samsung S630 LCD Display Replacement: paso 4, imagen 3 de 3
    • You now look directly onto the LCD.
    • Gently move the LCD out of the frame and fold it toward the bottom of the camera. Do not try to remove it. It is still attached.
    • Remove the four screws that hold the frame to the logic board.
  5. Samsung S630 LCD Display Replacement: paso 5, imagen 1 de 2 Samsung S630 LCD Display Replacement: paso 5, imagen 2 de 2
    • This particular camera has some Kapton tape holding the cable to the logic board. Gently remove it from the board only.
    • Open the locking tab on the PCB connector and remove the cable. This will separate the LCD from the board.
    • This is what the logic board looks like without the frame and the LCD.
Conclusión
3 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
784,286 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
558 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 2,647
