Saltar al contenido principal
Samsung Rogue Motherboard Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Samsung Rogue Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  2. Samsung Rogue Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  3. Samsung Rogue Motherboard Replacement: paso 3, imagen 1 de 3 Samsung Rogue Motherboard Replacement: paso 3, imagen 2 de 3 Samsung Rogue Motherboard Replacement: paso 3, imagen 3 de 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  4. Samsung Rogue Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  5. Samsung Rogue Motherboard Replacement: paso 5, imagen 1 de 2 Samsung Rogue Motherboard Replacement: paso 5, imagen 2 de 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  6. Samsung Rogue Motherboard Replacement: paso 6, imagen 1 de 2 Samsung Rogue Motherboard Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
Conclusión
Equipo
Cal Poly, Team 7-32, Maness Spring 2012 Miembro de Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 229
