Saltar al contenido principal
Samsung Rogue Keyboard Replacement
Qué necesitas
  1. Samsung Rogue Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Samsung Rogue Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Keyboard Replacement: paso 2, imagen 1 de 2 Samsung Rogue Keyboard Replacement: paso 2, imagen 2 de 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Keyboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Keyboard Replacement: paso 5, imagen 1 de 3 Samsung Rogue Keyboard Replacement: paso 5, imagen 2 de 3 Samsung Rogue Keyboard Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Keyboard Replacement: paso 6, imagen 1 de 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Keyboard Replacement: paso 7, imagen 1 de 2 Samsung Rogue Keyboard Replacement: paso 7, imagen 2 de 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Keyboard Replacement: paso 8, imagen 1 de 2 Samsung Rogue Keyboard Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Keyboard Replacement, Keyboard: paso 9, imagen 1 de 1
    • Remove the eight 1.7mm Philips screws above the keyboard.
  10. Samsung Rogue Keyboard Replacement: paso 10, imagen 1 de 1
    • Carefully remove keyboard holder from the slider mechanisms underneath.
  11. Samsung Rogue Keyboard Replacement: paso 11, imagen 1 de 2 Samsung Rogue Keyboard Replacement: paso 11, imagen 2 de 2
    • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
Conclusión
Equipo
Cal Poly, Team 7-32, Maness Spring 2012 Miembro de Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 299
