Saltar al contenido principal
Samsung Rant Rear Case Replacement
Qué necesitas
  1. Samsung Rant Rear Case Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: paso 3, imagen 1 de 1
    • Gently separate the rear case from the front case.
Conclusión
Denise Cooper
Miembro Desde 10/18/11
31 Reputación
3 Guías creadas
Equipo
James Madison, Team 1-6, Allen Fall 2011 Miembro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 1,142
