Introducción
In order to access the keypad, you must first remove the back cover, battery and rear case from the cell phone.
Partes
No se requieren partes.
  1. Turn phone over in the palm of your hand, with the screen facing down.
    • Turn phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off the phone.
    Agregar Comentario
  2. Place your thumb at the noched area at the bottom portion of the phone.
    • Place your thumb at the noched area at the bottom portion of the phone.
    • Gently lift up and pull the battery out in the opposite direction.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Take battery out of phone.
    Agregar Comentario
    • Hold the phone steady with one hand.
    • In the other hand use a philips screwdriver to loosen and remove all 3 screws.
    Agregar Comentario
    • Gently lift off the rear case from the front case.
    Agregar Comentario
    • Using a pair of tweezers, grip the keypad gently.
    • Lift the keypad out of the phone.
    Agregar Comentario
Conclusión
Denise Cooper
Miembro Desde 18/10/11
31 Reputación
3 Guías creadas
Equipo
James Madison, Team 1-6, Allen Fall 2011 Miembro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,049
