Saltar al contenido principal
Samsung Rant Battery Replacement
  1. Samsung Rant Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Carefully remove the battery from the phone.
Conclusión
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
Todd
Miembro Desde 10/18/11
1 Reputación
1 Guía escrita
Equipo
James Madison, Team 1-6, Allen Fall 2011 Miembro de James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Miembros
12 Guías creadas
Un comentario
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
Denise Cooper - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 1,448
