Saltar al contenido principal
Samsung Radiant360 R3 Tweeter Replacement
Qué necesitas
  1. Samsung Radiant360 R3 Tweeter Replacement, Wireless Setup Button and USB Module: paso 1, imagen 1 de 3 Samsung Radiant360 R3 Tweeter Replacement, Wireless Setup Button and USB Module: paso 1, imagen 2 de 3 Samsung Radiant360 R3 Tweeter Replacement, Wireless Setup Button and USB Module: paso 1, imagen 3 de 3
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Tweeter Replacement: paso 2, imagen 1 de 1
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Tweeter Replacement: paso 3, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement: paso 3, imagen 2 de 2
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Tweeter Replacement: paso 4, imagen 1 de 1
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Tweeter Replacement: paso 5, imagen 1 de 1
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Samsung Radiant360 R3 Tweeter Replacement, Wireless Module: paso 6, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement, Wireless Module: paso 6, imagen 2 de 2
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Samsung Radiant360 R3 Tweeter Replacement: paso 7, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement: paso 7, imagen 2 de 2
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Samsung Radiant360 R3 Tweeter Replacement: paso 8, imagen 1 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 8, imagen 2 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 8, imagen 3 de 3
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  9. Samsung Radiant360 R3 Tweeter Replacement: paso 9, imagen 1 de 1
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  10. Samsung Radiant360 R3 Tweeter Replacement: paso 10, imagen 1 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 10, imagen 2 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 10, imagen 3 de 3
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  11. Samsung Radiant360 R3 Tweeter Replacement: paso 11, imagen 1 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 11, imagen 2 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 11, imagen 3 de 3
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  12. Samsung Radiant360 R3 Tweeter Replacement: paso 12, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement: paso 12, imagen 2 de 2
    • Pry the two halves of the body open using a metal spudger.
  13. Samsung Radiant360 R3 Tweeter Replacement: paso 13, imagen 1 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 13, imagen 2 de 3 Samsung Radiant360 R3 Tweeter Replacement: paso 13, imagen 3 de 3
    • Remove the plugs located topmost right and closest to the bottom in picture.
  14. Samsung Radiant360 R3 Tweeter Replacement: paso 14, imagen 1 de 1
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  15. Samsung Radiant360 R3 Tweeter Replacement: paso 15, imagen 1 de 1
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
  16. Samsung Radiant360 R3 Tweeter Replacement, Subwoofer: paso 16, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement, Subwoofer: paso 16, imagen 2 de 2
    • Disconnect the plug in the device.
  17. Samsung Radiant360 R3 Tweeter Replacement: paso 17, imagen 1 de 1
    • Slide the subwoofer out of the speaker.
  18. Samsung Radiant360 R3 Tweeter Replacement, Motherboard: paso 18, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement, Motherboard: paso 18, imagen 2 de 2
    • Disconnect the six plugs on the motherboard.
  19. Samsung Radiant360 R3 Tweeter Replacement: paso 19, imagen 1 de 1
    • Remove the ZIF cable.
    • Pull up the tab with a spudger, and life the cable.
  20. Samsung Radiant360 R3 Tweeter Replacement: paso 20, imagen 1 de 2 Samsung Radiant360 R3 Tweeter Replacement: paso 20, imagen 2 de 2
    • Remove the four 12mm screws with the Phillips #1 screwdriver .
    • Remove the motherboard from the device.
  21. Samsung Radiant360 R3 Tweeter Replacement, Tweeter: paso 21, imagen 1 de 1
    • Remove the six 8mm screws using the Phillips #1 screwdriver.
    • Remove the six 12mm screws using the Phillips #1 screwdriver.
  22. Samsung Radiant360 R3 Tweeter Replacement: paso 22, imagen 1 de 1
    • Remove the six 12mm screws with the Phillips #1 screwdriver.
  23. Samsung Radiant360 R3 Tweeter Replacement: paso 23, imagen 1 de 1
    • Remove the touch panel by sliding it off the end.
  24. Samsung Radiant360 R3 Tweeter Replacement: paso 24, imagen 1 de 1
    • Remove the tweeter speaker from the casing.
Conclusión
Una persona más ha completado esta guía.
Fadi Alzammar
Miembro Desde 04/22/18
782 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S25-G18, Maness Spring 2018 Miembro de Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 227
