Saltar al contenido principal
Samsung Q330 Thermal Paste and Pad Replacement
Qué necesitas
  1. Samsung Q330 Thermal Paste and Pad Replacement, Opening the back panel.: paso 1, imagen 1 de 2 Samsung Q330 Thermal Paste and Pad Replacement, Opening the back panel.: paso 1, imagen 2 de 2
    • Unscrew all the screws holding the back panel in place.
    • Remove the battery and the small panel to reveal more screws.
    • Remove the HDD and RAM.
    • Slide out the DVD drive.
  2. Samsung Q330 Thermal Paste and Pad Replacement, Changing the thermal paste (1).: paso 2, imagen 1 de 3 Samsung Q330 Thermal Paste and Pad Replacement, Changing the thermal paste (1).: paso 2, imagen 2 de 3 Samsung Q330 Thermal Paste and Pad Replacement, Changing the thermal paste (1).: paso 2, imagen 3 de 3
    • Unscrew the heatsink and fan assembly.
    • Disconnect the fan, display and power connectors.
    • You can open the fan itself to clean it further.
    • Clean the old thermal paste from the heatsink and replace the pad if necessary. Be sure to use the same thinkness pad.
  3. Samsung Q330 Thermal Paste and Pad Replacement, Changing the thermal paste (2).: paso 3, imagen 1 de 2 Samsung Q330 Thermal Paste and Pad Replacement, Changing the thermal paste (2).: paso 3, imagen 2 de 2
    • Clean the old thermal paste. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the chips.
    • Don`t use too much thermal paste, just enough to cover some portion of the dye. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
  4. Samsung Q330 Thermal Paste and Pad Replacement, Upgrading the RAM and SSD (Optional): paso 4, imagen 1 de 1
    • Once you opened the back cover, it is a good idea to upgrade the SSD and RAM if you want.
Conclusión
Una persona más ha completado esta guía.
Simeon Brankov
Miembro Desde 11/08/20
7,297 Reputación
54 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 254
