Saltar al contenido principal
Samsung Propel Motherboard Replacement
Qué necesitas
  1. Samsung Propel Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back panel of the phone.
  2. Samsung Propel Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the old battery and replace with the new one.
  3. Samsung Propel Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use a flat-head screwdriver to remove the back lid.
  4. Samsung Propel Motherboard Replacement: paso 4, imagen 1 de 1
    • Locate the six screws and remove them with a Phillips #00 Screwdriver.
    • Insert the flat-head screwdriver into the crevice.
    • Slide and dislodge the snap-ons that are beneath the crevice.
    • Remove the back frame of the device.
  5. Samsung Propel Motherboard Replacement: paso 6, imagen 1 de 1
    • Locate and remove the six screws with a Phillips #00 Screwdriver.
    • Separate the black middle frame from the front frame.
    • Be careful not to tear the phone bus.
  6. Samsung Propel Motherboard Replacement: paso 7, imagen 1 de 1
    • Locate and remove the four screws with a Phillips #00 Screwdriver.
    • Slide the flat-head screwdriver and dislodge the snap-ons beneath the crevice.
    • Be careful not to rip the band.
  7. Samsung Propel Motherboard Replacement: paso 9, imagen 1 de 1
    • Use your hands to remove both the phone buses from the linkages and remove the motherboard.
Conclusión
Minh
Miembro Desde 04/28/11
201 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,769
