Introducción
This guide will teach you how to access and replace/clean the powerbrush of your POWERbot. This can be done to make your POWERbot clean more efficiently.
2 comentarios
The brush is wobbly in position. Is there an insert on the right side of the brush at the bearing. This position, the bearing look too small for the opening of the cover and the upper plastic.
Did you lose the rubber cover/ washer that goes over the bearing? You can replace it from Samsung if you did.
