Saltar al contenido principal
Samsung POWERbot R7070 Right Driving Wheel Replacement
Qué necesitas
  1. Samsung POWERbot R7070 Right Driving Wheel Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 2, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 2, imagen 2 de 2
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 3, imagen 1 de 1
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 4, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 4, imagen 2 de 2
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 5, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 5, imagen 2 de 2
    • Lift the battery from the right side, up and out of its compartment.
  6. Samsung POWERbot R7070 Right Driving Wheel Replacement, Motor: paso 6, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement, Motor: paso 6, imagen 2 de 2
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 7, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 7, imagen 2 de 2
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 8, imagen 1 de 1
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 9, imagen 1 de 1
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 10, imagen 1 de 1
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 11, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 11, imagen 2 de 2
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 12, imagen 1 de 1
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 13, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 13, imagen 2 de 2
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
  14. Samsung POWERbot R7070 Right Driving Wheel Replacement, Right Driving Wheel: paso 14, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement, Right Driving Wheel: paso 14, imagen 2 de 2
    • With the spring fully retracted, unhook the spring from the wheel casing.
  15. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 15, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 15, imagen 2 de 2
    • Remove the screw securing the black plastic piece to the right of the wheel casing.
    • This piece is not part of the wheel casing but must be unscrewed to remove the wheel casing.
    • Lift wheel and wheel casing out of vacuum base.
  16. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 16, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 16, imagen 2 de 2
    • Remove the three screws fastening the two halves of the wheel casing together.
  17. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 17, imagen 1 de 2 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 17, imagen 2 de 2
    • Separate the unsecured half of the wheel casing, exposing the wheel.
  18. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 18, imagen 1 de 1
    • Remove the three screws on the remaining half of the wheel casing.
  19. Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 19, imagen 1 de 3 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 19, imagen 2 de 3 Samsung POWERbot R7070 Right Driving Wheel Replacement: paso 19, imagen 3 de 3
    • Unscrew the black 1 cm screw securing the center of the wheel.
    • Remove the wheel.
Conclusión
7 personas más completaron esta guía.
Lauren Nubla
Miembro Desde 09/11/17
289 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S2-G8, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G8, Bruce Fall 2017
CSUF-BRUCE-F17S2G8
3 Miembros
10 Guías creadas
3 comentarios
Where can you find the replacement left driving wheel? are all the model the same?
ghvolleyball - Contestar
Very helpful, thank you.
Just beware of the rubber vacuum part and it’s placement after taking apart the vacuum.
James MacKenzie - Contestar
Very clear and helpful. Thank you
Able to replace the wheel quickly. Did not need to do steps 16-19 because new part came complete with new wheel.
Andy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,600
