Introducción
Replace the SD card on your Samsung PL200 to provide more memory space as well as replacing a defective card. This is a simple replacement that requires no tools and can be completed in less than 2 minutes.
Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
Once opened, the SD card should be visible.
Una persona más ha completado esta guía.
