Saltar al contenido principal
Samsung PL200 SD card Replacement
  1. Samsung PL200 SD card Replacement, SD card: paso 1, imagen 1 de 2 Samsung PL200 SD card Replacement, SD card: paso 1, imagen 2 de 2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
    • Once opened, the SD card should be visible.
  2. Samsung PL200 SD card Replacement: paso 2, imagen 1 de 2 Samsung PL200 SD card Replacement: paso 2, imagen 2 de 2
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector.
    • This will cause the SD card to raise up enough to allow you to grab it with your fingers.
    • Use your fingers to remove the old SD card.
  3. Samsung PL200 SD card Replacement: paso 3, imagen 1 de 2 Samsung PL200 SD card Replacement: paso 3, imagen 2 de 2
    • Insert the new SD card into the SD card slot.
    • Make sure to push it down all the way until it clicks and remains flush with battery.
    • Close the battery/SD card compartment.
Conclusión
Una persona más ha completado esta guía.
Jacob Presnell
Miembro Desde 01/29/15
219 Reputación
2 Guías creadas
Equipo
Clemson, Team 15-7, Shirley Winter 2015 Miembro de Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 296
