Saltar al contenido principal
Samsung PL20 LCD Replacement
Qué necesitas
  1. Samsung PL20 LCD Replacement, LCD: paso 1, imagen 1 de 3 Samsung PL20 LCD Replacement, LCD: paso 1, imagen 2 de 3 Samsung PL20 LCD Replacement, LCD: paso 1, imagen 3 de 3
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: paso 2, imagen 1 de 3 Samsung PL20 LCD Replacement: paso 2, imagen 2 de 3 Samsung PL20 LCD Replacement: paso 2, imagen 3 de 3
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: paso 3, imagen 1 de 3 Samsung PL20 LCD Replacement: paso 3, imagen 2 de 3 Samsung PL20 LCD Replacement: paso 3, imagen 3 de 3
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
Conclusión
6 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
791,325 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
35 Miembros
603 Guías creadas
Un comentario
Great help! Screen replaced no problem. Thank you
EE61 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 3,592
