Saltar al contenido principal
Samsung Odyssey NP800G5M Fan Replacement
Qué necesitas
  1. Samsung Odyssey NP800G5M Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Fan Replacement: paso 2, imagen 1 de 2 Samsung Odyssey NP800G5M Fan Replacement: paso 2, imagen 2 de 2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Fan Replacement: paso 3, imagen 1 de 2 Samsung Odyssey NP800G5M Fan Replacement: paso 3, imagen 2 de 2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Fan Replacement: paso 4, imagen 1 de 3 Samsung Odyssey NP800G5M Fan Replacement: paso 4, imagen 2 de 3 Samsung Odyssey NP800G5M Fan Replacement: paso 4, imagen 3 de 3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Fan Replacement, Fan: paso 5, imagen 1 de 3 Samsung Odyssey NP800G5M Fan Replacement, Fan: paso 5, imagen 2 de 3 Samsung Odyssey NP800G5M Fan Replacement, Fan: paso 5, imagen 3 de 3
    • Disconnect the fans from the motherboard by pulling the plugs away from their connectors.
    • Using the Phillips #0 screwdriver, remove the four 4.6mm screws.
    • Using the same screwdriver, unscrew the six screws surrounding the heat sink.
    • These screws cannot be removed from the device.
    • Remove the fan assembly from the device.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,252
