Saltar al contenido principal
Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement
Qué necesitas
  1. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 3, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 5, imagen 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 5, imagen 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the cover plate in place.
  7. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 7, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 7, imagen 2 de 2
    • Remove the black ribbon cable by pulling up on the black cover and sliding out the cable.
  8. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 8, imagen 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 8, imagen 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 8, imagen 3 de 3
    • Remove the three black and white cables by gently pulling on them.
  9. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 9, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: paso 9, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the USB board down and remove the board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 720
