Saltar al contenido principal
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
Qué necesitas
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 2, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 3, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 4, imagen 1 de 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 5, imagen 1 de 3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 5, imagen 2 de 3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 5, imagen 3 de 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: paso 6, imagen 1 de 1
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: paso 8, imagen 1 de 1
    • Pull the hard drive away from the cradle and remove it from the device.
Conclusión
2 comentarios
Would you point out where the SSD slot would be?
aroyphillips - Contestar
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 42
Todo El Tiempo: 3,215
