Saltar al contenido principal
Samsung Notebook 5 NP530E5M RAM Replacement
Qué necesitas
  1. Samsung Notebook 5 NP530E5M RAM Replacement, RAM: paso 1, imagen 1 de 2 Samsung Notebook 5 NP530E5M RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the single 6.5 mm screw that secures the plastic door labeled "Memory" to the bottom case.
    • Set the screw to the side in a secure location.
  2. Samsung Notebook 5 NP530E5M RAM Replacement: paso 2, imagen 1 de 1
    • Insert a spudger or opening pick under the door, and pry it open.
  3. Samsung Notebook 5 NP530E5M RAM Replacement: paso 3, imagen 1 de 1
    • Use a pry tool to disengage the pressure clamps holding both sides of the RAM chip.
    • Open both sides simultaneously to release the RAM module.
    • Once released, the existing RAM will pop upward.
  4. Samsung Notebook 5 NP530E5M RAM Replacement: paso 4, imagen 1 de 1
    • Gripping from the sides, gently pull the RAM from its seat.
    • Be careful not to break or bend the leads on the RAM, as this would render the unit useless.
  5. Samsung Notebook 5 NP530E5M RAM Replacement: paso 5, imagen 1 de 2 Samsung Notebook 5 NP530E5M RAM Replacement: paso 5, imagen 2 de 2
    • Align the new unit with the RAM slot, and insert the RAM stick at a slight angle, it will rest loosely in its seat.
    • Lightly press down on the RAM until you hear a "snap". This means that the latches have clasped shut, securing the RAM stick.
    • There are two RAM slots in the Samsung Notebook 5 NP530E5M. We recommend that you install the first RAM in the bottom slot, in case you decide to add more RAM later, you wont need to worry about removing your first stick.
    • Replace the memory door and secure the screw. Tightening the screw, but be careful not to apply to much torque, "stripping" the screw, rendering it useless.
Conclusión
Una persona más ha completado esta guía.
Lucas Gil
Miembro Desde 09/07/23
690 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-1, Gonzalez Fall 2023 Miembro de Gateway, Team 1-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 23
Todo El Tiempo: 126
