Saltar al contenido principal
Samsung Notebook 5 NP530E5M Battery Replacement
Qué necesitas
  1. Samsung Notebook 5 NP530E5M Battery Replacement, Bottom Case: paso 1, imagen 1 de 1
    • Flip the laptop over to access the bottom case.
    • Using a Phillips #000 screwdriver, remove the ten 6mm screws that secure the bottom case.
  2. Samsung Notebook 5 NP530E5M Battery Replacement: paso 2, imagen 1 de 2 Samsung Notebook 5 NP530E5M Battery Replacement: paso 2, imagen 2 de 2
    • Pry along the seam using an iFixit opening tool.
    • Lift off the bottom case.
  3. Samsung Notebook 5 NP530E5M Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Locate the battery towards the bottom left corner of the laptop.
  4. Samsung Notebook 5 NP530E5M Battery Replacement: paso 4, imagen 1 de 3 Samsung Notebook 5 NP530E5M Battery Replacement: paso 4, imagen 2 de 3 Samsung Notebook 5 NP530E5M Battery Replacement: paso 4, imagen 3 de 3
    • Using a spudger or iFixit opening tool, loosen the bundled power cable from its connector on the motherboard.
    • Disconnect the bundled cable connector.
  5. Samsung Notebook 5 NP530E5M Battery Replacement: paso 5, imagen 1 de 3 Samsung Notebook 5 NP530E5M Battery Replacement: paso 5, imagen 2 de 3 Samsung Notebook 5 NP530E5M Battery Replacement: paso 5, imagen 3 de 3
    • Using the Phillips #000 screwdriver, remove the three 5 mm screws holding the battery in place.
    • The screws are towards three corners of the battery, although there is an extra screw mount on the battery that is not used in this model of laptop.
  6. Samsung Notebook 5 NP530E5M Battery Replacement: paso 6, imagen 1 de 2 Samsung Notebook 5 NP530E5M Battery Replacement: paso 6, imagen 2 de 2
    • There is a "lip" in the bottom right corner of the battery mount.
    • Gently grip the battery from the sides, lift up and and to the left to remove the battery from its place.
Conclusión
Lucas Gil
Miembro Desde 09/07/23
690 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-1, Gonzalez Fall 2023 Miembro de Gateway, Team 1-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 148
