Introducción
If your home and play buttons are not working on your Samsung NX2000, we are here to show you step-by-step how you can replace them yourself. It will connect with the previous LCD display replacement guide and show you the correct way to remove this button.
Qué necesitas
First begin by flipping your camera upside down.
Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
Herramienta utilizada en este paso:Tweezers$4.99
Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
Detach the two ribbon cables, by first lifting the black tab on top of the connector.
Pull the ribbon cables out of the connectors with tweezers or two fingers.
Una persona más ha completado esta guía.
