Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If your camera's LCD is not working properly and the display has black spots or is all white you may need to replace it. Before taking apart the camera, make sure the power is off and the battery is removed.
  1. Locate the bottom panel of the camera.
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Pry open the back panel using the metal spudger. Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera.  Do not jam the tool in this part or the ribbon will rip.
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Open the two halves of the camera, taking care not to disturb the ribbon cable. Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the  next step
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger. Push the ribbon out of its socket with the plastic opening tool. Push the ribbon out of its socket with the plastic opening tool.
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  6. Completely separate the back panel from the camera. Completely separate the back panel from the camera.
    • Completely separate the back panel from the camera.
  7. Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver. Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  8. Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon. Using both thumbs push the ribbon out of the ZIF connection. Using both thumbs push the ribbon out of the ZIF connection.
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  9. Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  10. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs. Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
    • Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
  11. Separate the LCD from the back panel. Separate the LCD from the back panel.
    • Separate the LCD from the back panel.
Conclusión
Yesenia
Miembro Desde 22/01/15
717 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-13, Maness Winter 2015 Miembro de Cal Poly, Team 20-13, Maness Winter 2015
CPSU-MANESS-W15S20G13
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 914
