Introducción
If your camera's LCD is not working properly and the display has black spots or is all white you may need to replace it. Before taking apart the camera, make sure the power is off and the battery is removed.
Qué necesitas
Locate the bottom panel of the camera.
Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
