Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Introducción
This guide will show you how to separate the back panel from the camera. Before starting the guide make sure the camera is powered off and the memory card is removed.
  1. Locate the bottom panel of the camera.
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver. Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Pry open the back panel using the metal spudger. Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera.  Do not jam the tool in this part or the ribbon will rip.
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Open the two halves of the camera, taking care not to disturb the ribbon cable. Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the  next step
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger. Push the ribbon out of its socket with the plastic opening tool. Push the ribbon out of its socket with the plastic opening tool.
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  6. Completely separate the back panel from the camera. Completely separate the back panel from the camera.
    • Completely separate the back panel from the camera.
Conclusión
Una persona más ha completado esta guía.
Yesenia
Miembro Desde 22/01/15
717 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-13, Maness Winter 2015 Miembro de Cal Poly, Team 20-13, Maness Winter 2015
CPSU-MANESS-W15S20G13
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 94
