Introducción
If your backpanel is cracked or you wish to change the color with one you found online, here is the guide you are looking for! Be sure to turn off the camera and remove the battery before you begin the replacement.
Qué necesitas
Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
Casi Terminas!
Conclusión
