Saltar al contenido principal
Samsung NX1 Viewfinder Replacement
Qué necesitas
  1. Samsung NX1 Viewfinder Replacement, Viewfinder Focus Dial: paso 1, imagen 1 de 2 Samsung NX1 Viewfinder Replacement, Viewfinder Focus Dial: paso 1, imagen 2 de 2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Viewfinder Replacement: paso 2, imagen 1 de 2 Samsung NX1 Viewfinder Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Viewfinder Replacement, Back Cover: paso 3, imagen 1 de 3 Samsung NX1 Viewfinder Replacement, Back Cover: paso 3, imagen 2 de 3 Samsung NX1 Viewfinder Replacement, Back Cover: paso 3, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Viewfinder Replacement: paso 4, imagen 1 de 2 Samsung NX1 Viewfinder Replacement: paso 4, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Viewfinder Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Viewfinder Replacement: paso 6, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Viewfinder Replacement: paso 7, imagen 1 de 3 Samsung NX1 Viewfinder Replacement: paso 7, imagen 2 de 3 Samsung NX1 Viewfinder Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Viewfinder Replacement: paso 8, imagen 1 de 2 Samsung NX1 Viewfinder Replacement: paso 8, imagen 2 de 2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Viewfinder Replacement: paso 9, imagen 1 de 3 Samsung NX1 Viewfinder Replacement: paso 9, imagen 2 de 3 Samsung NX1 Viewfinder Replacement: paso 9, imagen 3 de 3
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  10. Samsung NX1 Viewfinder Replacement, LCD Touch Screen: paso 10, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven screws (three silver 3.5 mm screws and four black 2.7 mm screws).
  11. Samsung NX1 Viewfinder Replacement: paso 11, imagen 1 de 2 Samsung NX1 Viewfinder Replacement: paso 11, imagen 2 de 2
    • Use tweezers to remove the glued rubber piece.
  12. Samsung NX1 Viewfinder Replacement: paso 12, imagen 1 de 3 Samsung NX1 Viewfinder Replacement: paso 12, imagen 2 de 3 Samsung NX1 Viewfinder Replacement: paso 12, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the four black 2.3 mm screws.
    • Use your fingers to separate the LCD screen from the folding mechanism.
  13. Samsung NX1 Viewfinder Replacement, Motherboard: paso 13, imagen 1 de 1
    • Use tweezers to pull the five ribbon cables horizontally out of their clips.
    • Use a spudger or your fingernail to flip up the four, small retaining flap, or zero insertion force (ZIF) connectors. Then, pull the ribbon cable out to disconnect it.
    • Remove the green tape using your fingernail. Then, use a spudger to pry the one antenna cable connector straight up from the board.
    • Use tweezers or a spudger to pry up each side of the flat-topped connector. Then, lift the one connector straight up from its socket.
    • Use tweezers or your fingers to pull the two double-bundled cables up and away from the connector in the same direction that the individual wires are running.
  14. Samsung NX1 Viewfinder Replacement: paso 14, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the six silver 4.5 mm screws.
  15. Samsung NX1 Viewfinder Replacement: paso 15, imagen 1 de 2 Samsung NX1 Viewfinder Replacement: paso 15, imagen 2 de 2
    • Use a spudger to lift the motherboard up starting on the right side proceeding to the left side.
    • Use your fingers to lift the motherboard completely out of the camera.
  16. Samsung NX1 Viewfinder Replacement, Viewfinder: paso 16, imagen 1 de 1
    • Use tweezers to lift the black tab on the ZIF connector.
    • Use tweezers to pull the large orange ribbon cable out of the connector to get a clearer view of the screws lying beneath it.
  17. Samsung NX1 Viewfinder Replacement: paso 17, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the three black 3.8 mm screws below the viewfinder.
  18. Samsung NX1 Viewfinder Replacement: paso 18, imagen 1 de 2 Samsung NX1 Viewfinder Replacement: paso 18, imagen 2 de 2
    • Use a spudger to gently push the viewfinder cube, starting at the top of the cube and pushing it toward the bottom of the camera.
    • Use your fingers to lift the viewfinder cube out of the camera.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-4, Leahy Spring 2016 Miembro de USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,072
