Saltar al contenido principal
Samsung NX1 Navigation Buttons Replacement
Qué necesitas
  1. Samsung NX1 Navigation Buttons Replacement, Viewfinder Focus Dial: paso 1, imagen 1 de 2 Samsung NX1 Navigation Buttons Replacement, Viewfinder Focus Dial: paso 1, imagen 2 de 2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Navigation Buttons Replacement: paso 2, imagen 1 de 2 Samsung NX1 Navigation Buttons Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Navigation Buttons Replacement, Back Cover: paso 3, imagen 1 de 3 Samsung NX1 Navigation Buttons Replacement, Back Cover: paso 3, imagen 2 de 3 Samsung NX1 Navigation Buttons Replacement, Back Cover: paso 3, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Navigation Buttons Replacement: paso 4, imagen 1 de 2 Samsung NX1 Navigation Buttons Replacement: paso 4, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Navigation Buttons Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Navigation Buttons Replacement: paso 6, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Navigation Buttons Replacement: paso 7, imagen 1 de 3 Samsung NX1 Navigation Buttons Replacement: paso 7, imagen 2 de 3 Samsung NX1 Navigation Buttons Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Navigation Buttons Replacement: paso 8, imagen 1 de 2 Samsung NX1 Navigation Buttons Replacement: paso 8, imagen 2 de 2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Navigation Buttons Replacement: paso 9, imagen 1 de 3 Samsung NX1 Navigation Buttons Replacement: paso 9, imagen 2 de 3 Samsung NX1 Navigation Buttons Replacement: paso 9, imagen 3 de 3
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  10. Samsung NX1 Navigation Buttons Replacement, Navigation Buttons: paso 10, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the six screws (three silver 3.5 mm screws and three black 4.2 mm screws).
  11. Samsung NX1 Navigation Buttons Replacement: paso 11, imagen 1 de 1
    • Use the tweezers to pull the blue ribbon cable horizontally out of its clip.
  12. Samsung NX1 Navigation Buttons Replacement: paso 12, imagen 1 de 2 Samsung NX1 Navigation Buttons Replacement: paso 12, imagen 2 de 2
    • Use your fingers to remove the metal piece with the blue ribbon cable and the rubber buttons lying underneath.
Conclusión
Equipo
USF Tampa, Team 1-4, Leahy Spring 2016 Miembro de USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 526
