Introducción
Is your camera exhibiting symptoms of a faulty motherboard? This guide will help you access the motherboard to replace it or make necessary repairs.
Qué necesitas
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
Una persona más ha completado esta guía.
