Introducción
Use this guide to replace a damaged front case or open the case to access other components of your camera.
Herramientas
Partes
No se especificaron partes.
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Casi Terminas!
Conclusión
