Saltar al contenido principal
Samsung NT300E5X-AD5S Hard Drive Replacement
Qué necesitas
  1. Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): paso 1, imagen 1 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): paso 1, imagen 2 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): paso 1, imagen 3 de 3
    • Place the laptop with the backside facing up.
    • Remove the battery from the device by pushing out the slide locks to either end.
    • When reassembling the battery, you only need to push it back into its position.
  2. Samsung NT300E5X-AD5S Hard Drive Replacement: paso 2, imagen 1 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 2, imagen 2 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #00 screwdriver, loosen the 4 mm screw.
    • Remove the ODD/HDD/Memory panel by pushing it towards you.
  3. Samsung NT300E5X-AD5S Hard Drive Replacement: paso 3, imagen 1 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 3, imagen 2 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws.
    • Carefully lift the mounting bracket out of the laptop.
  4. Samsung NT300E5X-AD5S Hard Drive Replacement: paso 4, imagen 1 de 2 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 4, imagen 2 de 2
    • Hold the base of the connector under the hard drive disk (HDD).
    • Gently pull out the connector and separate the HDD from the device.
  5. Samsung NT300E5X-AD5S Hard Drive Replacement: paso 5, imagen 1 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 5, imagen 2 de 3 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 5, imagen 3 de 3
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws from the mounting bracket.
    • Take off the HDD from the mounting bracket.
  6. Samsung NT300E5X-AD5S Hard Drive Replacement: paso 6, imagen 1 de 2 Samsung NT300E5X-AD5S Hard Drive Replacement: paso 6, imagen 2 de 2
    • Put the new HDD or solid state drive (SSD) onto the mounting bracket and secure the new drive using the Phillips #00 screwdriver to replace the four 4 mm screws.
Conclusión
To reassemble your device, follow these instructions in reverse order. Turn on the laptop, and enter the BIOS setup by pressing the F2 button on the keyboard during the initial booting screen. Check the new drive at the section called "SATA Port 1".
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 849
