Saltar al contenido principal
Samsung NP900X4B Fan Replacement
Qué necesitas
  1. Samsung NP900X4B Fan Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung NP900X4B Fan Replacement, Back Panel: paso 1, imagen 2 de 2
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: paso 2, imagen 1 de 1
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: paso 3, imagen 1 de 2 Samsung NP900X4B Fan Replacement: paso 3, imagen 2 de 2
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: paso 4, imagen 1 de 2 Samsung NP900X4B Fan Replacement, Fan: paso 4, imagen 2 de 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: paso 5, imagen 1 de 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: paso 6, imagen 1 de 2 Samsung NP900X4B Fan Replacement: paso 6, imagen 2 de 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: paso 7, imagen 1 de 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Conclusión
Una persona más ha completado esta guía.
Brian Miller
Miembro Desde 10/17/18
333 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 174
