Saltar al contenido principal
Samsung NP540U3C-A02UB Speaker Replacement
Qué necesitas
  1. Samsung NP540U3C-A02UB Speaker Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Speaker Replacement: paso 2, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 2, imagen 2 de 2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Speaker Replacement: paso 3, imagen 1 de 3 Samsung NP540U3C-A02UB Speaker Replacement: paso 3, imagen 2 de 3 Samsung NP540U3C-A02UB Speaker Replacement: paso 3, imagen 3 de 3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Speaker Replacement: paso 4, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Speaker Replacement: paso 5, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Speaker Replacement: paso 6, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 6, imagen 2 de 2
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Speaker Replacement, Battery: paso 7, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement, Battery: paso 7, imagen 2 de 2
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Speaker Replacement: paso 8, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 8, imagen 2 de 2
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Speaker Replacement: paso 9, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 9, imagen 2 de 2
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Speaker Replacement: paso 10, imagen 1 de 1
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Speaker Replacement: paso 11, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 11, imagen 2 de 2
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Speaker Replacement: paso 12, imagen 1 de 3 Samsung NP540U3C-A02UB Speaker Replacement: paso 12, imagen 2 de 3 Samsung NP540U3C-A02UB Speaker Replacement: paso 12, imagen 3 de 3
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Speaker Replacement: paso 13, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 13, imagen 2 de 2
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Speaker Replacement: paso 14, imagen 1 de 1
    • Remove the battery from the laptop.
  15. Samsung NP540U3C-A02UB Speaker Replacement, Speaker: paso 15, imagen 1 de 3 Samsung NP540U3C-A02UB Speaker Replacement, Speaker: paso 15, imagen 2 de 3 Samsung NP540U3C-A02UB Speaker Replacement, Speaker: paso 15, imagen 3 de 3
    • Using the plastic opening tool, gently release the connector for the speaker(s) you are replacing.
    • These will be found on opposite sides of where the battery was attached.
  16. Samsung NP540U3C-A02UB Speaker Replacement: paso 16, imagen 1 de 2 Samsung NP540U3C-A02UB Speaker Replacement: paso 16, imagen 2 de 2
    • Using the metal spudger, scrape away the adhesive underneath the speaker that binds it to the laptop casing.
    • Remove the speaker from the case.
Conclusión
Alejandro
Miembro Desde 03/28/22
253 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 98
