Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung NP530U4BL RAM Replacement
Qué necesitas
  1. Samsung NP530U4BL RAM Replacement, Removing Back Cover: paso 1, imagen 1 de 1
    • Before disassembling your computer, make sure it is powered off.
    • Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
    • Removing these screws allows you to take off the panel on the right side of the laptop.
  2. Samsung NP530U4BL RAM Replacement: paso 2, imagen 1 de 2 Samsung NP530U4BL RAM Replacement: paso 2, imagen 2 de 2
    • Using your dominant hand, pinch the tab on the back panel to the right and remove it.
    • Using the Phillips #00 screwdriver, remove the two 1.5 mm screws that are under the panel.
    • You are now able to detach the entire back cover of the laptop. You can store these screws in the same area as the others because they are all 1.5 mm, identical parts.
  3. Samsung NP530U4BL RAM Replacement: paso 3, imagen 1 de 1
    • Be sure that you are looking at the laptop so that the spine connecting the base to the screen is at the top.
    • When using the plastic opening tool, be careful not to rip or pull too hard to disengage the prongs connecting the back cover to the base. Moving slowly will make this task easier and less likely to cause damage to your machine.
    • Using the plastic opening tool, start in the upper-left hand corner of the laptop and pry horizontally to the upper right-hand corner.
  4. Samsung NP530U4BL RAM Replacement: paso 4, imagen 1 de 1
    • Again starting in the upper left-hand corner, pry down vertically towards the bottom left-hand corner of the laptop.
    • You have now disengaged two of the four sides holding the back cover onto the base.
  5. Samsung NP530U4BL RAM Replacement: paso 5, imagen 1 de 2 Samsung NP530U4BL RAM Replacement: paso 5, imagen 2 de 2
    • Using your dominant hand, grasp the left side of the back cover and gently pull it up. This should disengage the prongs on the bottom and right edge of the base.
    • The right side of the cover has openings that go around the USB ports, the HDMI port, the Ethernet port, the VGA port, and the headphone jack. Use caution when disengaging the prongs around these parts.
    • After completing this step the entire back cover should be separated from the base, and the inside of the laptop should be revealed.
  6. Samsung NP530U4BL RAM Replacement: paso 6, imagen 1 de 2 Samsung NP530U4BL RAM Replacement: paso 6, imagen 2 de 2
    • All steps following the removal of the back cover should be completed while wearing an Anti static bracelet. This prevents ESD (electrostatic discharge). ESD can damage nearly every part on the inside of your computer.
  7. Samsung NP530U4BL RAM Replacement, RAM: paso 7, imagen 1 de 3 Samsung NP530U4BL RAM Replacement, RAM: paso 7, imagen 2 de 3 Samsung NP530U4BL RAM Replacement, RAM: paso 7, imagen 3 de 3
    • When working on the inside of the laptop, it is very easy to damage small pins and other parts of the machine. Keep your hands on the edges of the laptop unless instructed otherwise.
    • The RAM is kept in place by two silver tabs. To disengage these tabs, push them outwards at the same time, releasing the lock on the RAM.
    • RAM (the actual RAM is not pictured)
    • Using your dominant hand's index finger and thumb, squeeze the RAM gently on the two sides that were not held down by the pins and lift it horizontally from the base.
Conclusión
Una persona más ha completado esta guía.
Kayla Loycano
Miembro Desde 03/02/16
913 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 8-1, Botvin Spring 2016 Miembro de UMass Dartmouth, Team 8-1, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G1
Miembros de 4
6 Guías creadas
1Guía Comentario
Why this site is telling people to remove the whole of the back panel is beyond me. By removing the hard drive cover the ram slot is easily accessible. You only need to remove one screw to access it instead of the 10 recommended by this expert. If you are looking into upgrading your ram please remove the hard drive cover and just have a look at what is right there. Don’t need to be Bill Gates to see that it’s designed to be able to get to the ram slot from there. Good luck.
Macca Ronney - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 173
Todo El Tiempo: 1,449
