Saltar al contenido principal
Samsung NP510R5E-A01UB Speaker Replacement
Qué necesitas
  1. Samsung NP510R5E-A01UB Speaker Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Speaker Replacement: paso 2, imagen 1 de 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Speaker Replacement: paso 3, imagen 1 de 2 Samsung NP510R5E-A01UB Speaker Replacement: paso 3, imagen 2 de 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: paso 4, imagen 1 de 3 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: paso 4, imagen 2 de 3 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: paso 4, imagen 3 de 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Speaker Replacement: paso 5, imagen 1 de 2 Samsung NP510R5E-A01UB Speaker Replacement: paso 5, imagen 2 de 2
    • Untangle the wires attached to the exterior of the right speaker.
    • Lift the tape up holding the wires down to fully release the wires.
  6. Samsung NP510R5E-A01UB Speaker Replacement: paso 6, imagen 1 de 1
    • Unscrew the 3.4mm long screw holding the right speaker in place.
  7. Samsung NP510R5E-A01UB Speaker Replacement: paso 7, imagen 1 de 1
    • Pull up on the wires circled to disconnect the right speaker.
  8. Samsung NP510R5E-A01UB Speaker Replacement: paso 8, imagen 1 de 1
    • Using the plastic opening tool, pry up the right speaker and take it out.
  9. Samsung NP510R5E-A01UB Speaker Replacement: paso 9, imagen 1 de 1
    • Unscrew the 3.4mm long screw holding the left speaker in place.
  10. Samsung NP510R5E-A01UB Speaker Replacement: paso 10, imagen 1 de 1
    • Pull up on the wires to disconnect the left speaker.
  11. Samsung NP510R5E-A01UB Speaker Replacement: paso 11, imagen 1 de 1
    • Using the plastic opening tool, pry up the left speaker and take it out.
Conclusión
Una persona más ha completado esta guía.
Brian Briggs
Miembro Desde 02/14/18
529 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S6-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 236
