Saltar al contenido principal
Samsung NP510R5E-A01UB Motherboard Replacement
Qué necesitas
  1. Samsung NP510R5E-A01UB Motherboard Replacement, Back Case: paso 1, imagen 1 de 3 Samsung NP510R5E-A01UB Motherboard Replacement, Back Case: paso 1, imagen 2 de 3 Samsung NP510R5E-A01UB Motherboard Replacement, Back Case: paso 1, imagen 3 de 3
    • Lightly press down on the the back panel and pull away from the back case. The panel should slide away and detach from the back case.
  2. Samsung NP510R5E-A01UB Motherboard Replacement: paso 2, imagen 1 de 2 Samsung NP510R5E-A01UB Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the two rubber feet that have arrows pointing towards them. The rubber feet are very sticky so use the metal spudger to pry them up.
  3. Samsung NP510R5E-A01UB Motherboard Replacement: paso 3, imagen 1 de 1
    • Using the JIS #0 screwdriver, remove all the screws in the back case.
    • Unscrew the 9 black 6.5mm screws.
    • Unscrew the 4 silver 4.4mm screws.
  4. Samsung NP510R5E-A01UB Motherboard Replacement: paso 4, imagen 1 de 2 Samsung NP510R5E-A01UB Motherboard Replacement: paso 4, imagen 2 de 2
    • Using the spudger, insert it between the back case and the laptop. Pry up on the back case until the case pops up. Work the spudger all the way around the back case until the back case will lift off freely.
  5. Samsung NP510R5E-A01UB Motherboard Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  6. Samsung NP510R5E-A01UB Motherboard Replacement: paso 6, imagen 1 de 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  7. Samsung NP510R5E-A01UB Motherboard Replacement: paso 7, imagen 1 de 2 Samsung NP510R5E-A01UB Motherboard Replacement: paso 7, imagen 2 de 2
    • Unplug the connector from the hard drive by pulling straight out.
  8. Samsung NP510R5E-A01UB Motherboard Replacement, Battery: paso 8, imagen 1 de 3 Samsung NP510R5E-A01UB Motherboard Replacement, Battery: paso 8, imagen 2 de 3 Samsung NP510R5E-A01UB Motherboard Replacement, Battery: paso 8, imagen 3 de 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  9. Samsung NP510R5E-A01UB Motherboard Replacement: paso 9, imagen 1 de 3 Samsung NP510R5E-A01UB Motherboard Replacement: paso 9, imagen 2 de 3 Samsung NP510R5E-A01UB Motherboard Replacement: paso 9, imagen 3 de 3
    • Use the screwdriver to remove the four 3.5mm long screws holding the battery in place. Then carefully pull the battery's connector cable out to remove the battery.
  10. Samsung NP510R5E-A01UB Motherboard Replacement, Cooling Fan: paso 10, imagen 1 de 2 Samsung NP510R5E-A01UB Motherboard Replacement, Cooling Fan: paso 10, imagen 2 de 2
    • Unplug the fan cord.
  11. Samsung NP510R5E-A01UB Motherboard Replacement: paso 11, imagen 1 de 2 Samsung NP510R5E-A01UB Motherboard Replacement: paso 11, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the two 3.0mm screws.
    • Loosen the four spring loaded screws using the Phillips #0 screwdriver. These do NOT come out.
  12. Samsung NP510R5E-A01UB Motherboard Replacement: paso 12, imagen 1 de 3 Samsung NP510R5E-A01UB Motherboard Replacement: paso 12, imagen 2 de 3 Samsung NP510R5E-A01UB Motherboard Replacement: paso 12, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the five 3.0mm screws.
    • Remove the fan from the copper plate.
  13. Samsung NP510R5E-A01UB Motherboard Replacement, Motherboard: paso 13, imagen 1 de 3 Samsung NP510R5E-A01UB Motherboard Replacement, Motherboard: paso 13, imagen 2 de 3 Samsung NP510R5E-A01UB Motherboard Replacement, Motherboard: paso 13, imagen 3 de 3
    • Unplug the 9 cords shown here.
  14. Samsung NP510R5E-A01UB Motherboard Replacement: paso 14, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the four 3.0mm screws.
  15. Samsung NP510R5E-A01UB Motherboard Replacement: paso 15, imagen 1 de 2 Samsung NP510R5E-A01UB Motherboard Replacement: paso 15, imagen 2 de 2
    • Use the Phillips #0 screwdriver to take out the one 3 mm screw.
    • Take out the Wi-Fi Card.
  16. Samsung NP510R5E-A01UB Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
Sandhal Olds
Miembro Desde 03/25/19
283 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G2, Henning Spring 2019 Miembro de IUPUI, Team S2-G2, Henning Spring 2019
IUPUI-HENNING-S19S2G2
Miembros de 3
3 Guías creadas
1Guía Comentario
in step 13, what is the name of the connector for the display. thank you
Albert Mysh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 770
