Saltar al contenido principal
Samsung NP510R5E-A01UB Display Replacement
Qué necesitas
  1. Samsung NP510R5E-A01UB Display Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Display Replacement: paso 2, imagen 1 de 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Display Replacement: paso 3, imagen 1 de 2 Samsung NP510R5E-A01UB Display Replacement: paso 3, imagen 2 de 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Display Replacement, Display: paso 4, imagen 1 de 3 Samsung NP510R5E-A01UB Display Replacement, Display: paso 4, imagen 2 de 3 Samsung NP510R5E-A01UB Display Replacement, Display: paso 4, imagen 3 de 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Display Replacement: paso 5, imagen 1 de 2 Samsung NP510R5E-A01UB Display Replacement: paso 5, imagen 2 de 2
    • Disconnect the black and white cables by pulling up as pictured.
  6. Samsung NP510R5E-A01UB Display Replacement: paso 6, imagen 1 de 2 Samsung NP510R5E-A01UB Display Replacement: paso 6, imagen 2 de 2
    • Disconnect the black cable by pulling straight out.
  7. Samsung NP510R5E-A01UB Display Replacement: paso 7, imagen 1 de 3 Samsung NP510R5E-A01UB Display Replacement: paso 7, imagen 2 de 3 Samsung NP510R5E-A01UB Display Replacement: paso 7, imagen 3 de 3
    • Unscrew the two 4.45mm long screws to disconnect the left hinge.
    • Unscrew the two 4.45mm long screws to disconnect the right hinge.
    • At this point the screen and plastic housing should be completely disconnected.
  8. Samsung NP510R5E-A01UB Display Replacement: paso 8, imagen 1 de 2 Samsung NP510R5E-A01UB Display Replacement: paso 8, imagen 2 de 2
    • Using the plastic opening tool, pry open the plastic housing that holds the display.
  9. Samsung NP510R5E-A01UB Display Replacement: paso 9, imagen 1 de 2 Samsung NP510R5E-A01UB Display Replacement: paso 9, imagen 2 de 2
    • Unscrew the four 3.55mm long screws that hold the display in place.
  10. Samsung NP510R5E-A01UB Display Replacement: paso 10, imagen 1 de 2 Samsung NP510R5E-A01UB Display Replacement: paso 10, imagen 2 de 2
    • Disconnect the last cable by pulling straight out.
Conclusión
Dominic Simpson
Miembro Desde 02/14/18
245 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S6-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 670
